Any grinding for Prostars 15x10 4.5bs
Old 02-28-2009, 05:07 PM
RENE'S RAGE's Avatar
Default Any grinding for Prostars 15x10 4.5bs
Any grinding required on calipers with 15x10 w/4.5bs. I have 15x10 w/7.5bs now with spacers. Don't want to use spacers on new rims. Still waiting on my MWC FAB 9, narrowed 3" per side. Wanting to know in advance. Thanks George
Old 02-28-2009, 05:17 PM
SuperSlow02's Avatar
I was about to ask why you were going to a small BS, but id imagine yes, its the barrel of the wheel that is the problem with prostars. With my 15x8s and a 4.5 BS, I had to demolish my calipers to get them to fit.
Old 02-28-2009, 05:37 PM
I may be wrong but I"m thinking being a 10" rim I would have 2" more to work with. The barrel is not as small at the point of mounting. I'll pull my rims tommorow and fit these new ones on. Been to lazy and cold lately and car is also on dollys now.
Old 03-01-2009, 03:37 PM
cws T/A's Avatar
I dont think it matters the backspacing , the part I have X'd is the problem area with factory calipers .
The transition to where its flat to welded is the area where it gets to small and we have to grind . My brake pads are almost gone and I still had to grind the heck out out of my calipers . If they only made the 5star part that gets welded larger they would be flat and not have the transition slope and clear no problem .
Picture is a 15x10 , 7.5 backspacing Weld Prostar .
Old 03-02-2009, 07:31 AM
Thanks, did you run any spacer with these rims? I'm trying not to run a spacer.
Old 03-02-2009, 08:53 AM
ndfrsd6's Avatar
if you get drag brakes you will not need to grind .....but a cheap alternative is LT1 rear brakes ...
Old 03-02-2009, 10:02 AM
Sometimes yous till have to grind with LT1s, we had to on my friends car(conversion)
Old 03-02-2009, 11:13 AM
How much are drag brakes? How much is involded in the LT1 swap? This car is putting me in the poor house. And my wife is fixing to leave me. Which might be a good thing, but who's going to bring my to me?
Old 03-02-2009, 11:56 AM
ndfrsd6's Avatar
^^ lol join the club .... rear drag brakes are around 500 ish for strange and LT1 brakes dont roll as well as LS1's, so i would just grind the LS1's till you can afford drag brakes thats what i did ....
Old 03-02-2009, 01:46 PM
Yeah I was thinking around $600, But didn't know for sure, Just going to grind until the fluid comes out, then tell the ol' lady, Damn I need some STRANGE.......brakes honey.
Old 03-03-2009, 02:10 PM
ndfrsd6's Avatar
^^ lol thats one way to do it
Quick Reply: Any grinding for Prostars 15x10 4.5bs
