700rwhp setup
700rwhp setup
I have a 6.0 that im building up with 408 stroker kit, ls6 cam, and waiting for the new edelbrock intake to come out to use that for the build. Im sticking with the stock 317 heads but with the upgraded dual springs.
What size injectors, what size single turbo, and what amount of boost am i looking at to hit 700rwhp.
This is through a 4l80 and 93 octane, and if i have to use a meth kit that is fine as ive used them before.
I have 60s on my 408 with hogged out 317s & an F1. Just make sure the fuel system will keep up (like a Nasty Stage 3 w/dual Walbros). Meth will help keep the knock down running 93 & adds a little hp if you run pure.
Have dual walbros coming from lonnies performance.
The main thing is the 93 octane though, drive it all the time so race gas is no option, ive ran meth on my previous procharged buick motor so it wont be a problem with the new setup, and an intercooler with this setup will help as well as having lower compression as well.
Also been thinking about going back to procharger now instead of the turbo route. My buick motor that i pulled out of the car had a D1sc on it and it was a blast and the power seemed to come at any rpm or road speed in an instant.
My motor is a lq9 but i have no accessories on the front of the motor. Ill have an electric water pump and a low mount alternator.
Does anyone on the board make a kit that will bolt to the heads or any other stock bolt location type setup? Looking to do a F1 if it matters.
thanks. that def. looks like what ill be getting from one of the sponsors once it comes out and funds are back up from my swap.
I would go with the cog system for zero belt slip, but both pics of the setup from the link you provided show the motors with the power steering. They will obv. clear my elec waterpump and low mount alt, but cant tell exactly what holes or stock bracket the procharger bracket bolts to.
