Transmission experts I think I got my first problem
Old 02-28-2009, 10:33 PM
Intercooler2's Avatar
Default Transmission experts I think I got my first problem
And hope it isn't bad. So I have 33k original miles and put a converter in about two weeks ago. Has driven fine since but tonight kind of out of the blue the SES light come on and the car wouldn't really leave from the stop light. It was like I had a 5k stall and then it wouldn't auto upshift but I could move the shifter and it would clunk into a gear. I also could never get it into OD, it was like it just wasn't there or couldn't feel the converter lock-up. When in gear (think D was okay) and I gave it some gas it would move out good when cruising along. Is it hosed or maybe an electrical gremlin?
Old 02-28-2009, 10:54 PM
crmartin99's Avatar
had i tuned yet?
Old 02-28-2009, 11:12 PM
Nope. I was waiting to put the valve springs and rockers on first. I had it tuned before but not since the converter.
Old 02-28-2009, 11:34 PM
Closed ex-Sponsor Account
tptransmission's Avatar
You will set a trans code with a stall converter. You need to get the code disabled.
Old 02-28-2009, 11:58 PM
Do you think that is the problem I am seeing? Can I disconnect the battery to clear it (and hopefully make it right again) until I get the rockers and all changed?
I ran it for 2 weeks without issue though. I pulled out of a parking lot tonight, SES lights up and it would barely move away from stop light. Then no OD and or upshifts.
Old 03-01-2009, 12:03 AM
It will clear but will return again until you get the diagnostic code turned off. Verify what code is setting first to make sure something else is not going on.
Old 03-01-2009, 01:05 AM
GT Griller's Avatar
Sounds like ur in limp mode and stuck in 3rd gear......a higher stall will cause u to throw some shift solenoid codes but i dont think ive ever see it go into limp mode.....do u have a cooler on it?
Old 03-01-2009, 01:21 AM
LS1Tech Sponsor
performabuilt's Avatar
Your setting code PO757 have the test for the code removed and all will be fine again
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 03-01-2009, 06:51 AM
Wow! You even know the code! Anywhere to read what that one is and how it defines my issue?
Closest place is 20 miles away and I fear damage driving it like this unless a battery reset will make it okay. Maybe I can put an ad out there for someone to meet me with a tuner (what kind can remove it?) and clear it.
Old 03-01-2009, 11:11 AM
GT Griller's Avatar
U dont have an autozone in town?
Old 03-01-2009, 11:59 AM
I do and they can clear the code. Question is from the house to there. Will taking the battery terminal off clear it so it drives normal?
Old 03-01-2009, 12:00 PM
LS1Tech Sponsor
You will need something like the diablo, hptuners or efilve to remove the test for the code simply clearing it will not solve the issue.
After you do that you should be good to go.
__________________
Call 888-744-6542
Old 03-01-2009, 01:07 PM
Removing the battery terminal clear it long enough to get it to Autozone?
Old 03-01-2009, 01:21 PM
9000th01ss's Avatar
Yea, it's buried neck deep in one of the most random stickies I've ever took the time to read.
https://ls1tech.com/forums/9817507-post26.html
You'd never expect to find it, but it's in here. -->>> https://ls1tech.com/forums/automatic...lush-more.html
Old 03-01-2009, 01:34 PM
LS1Tech Sponsor
It is a little random However I actually created it in such a way the titles of each post are supposed to be searchable though key words to find what your looking for. The other option would have been many separate threads so I thought that was the best way to get what i was looking to acomplish.
__________________
Call 888-744-6542
Old 03-01-2009, 01:39 PM
9000th01ss's Avatar
I was thinking of that, it is random, I didn't expect to find that info in it but I read it all and it was exactly what I was looking for.
I thought I should add that it is very informative, random might sound bad I don't know. But it is very informative and full of useful information.
Old 03-01-2009, 02:08 PM
Guess I need to post an add for someone to pay me a visit and turn the code off LOL
Old 03-05-2009, 05:12 PM
So I rented a scanner from AutoZone today and cleared the code PO757 and it is working like normal again... so good info here! I'm keeping the scanner until I get the rear swapped and the other stuff before going back to the dyno. Won't be long though and I will need a trans. I can feel it coming! I am debating on whether to do the 4L60 or go TH-400
Old 03-05-2009, 07:33 PM
LS1Tech Sponsor
If you like driving that car and dont wanna loose 30 percent of your fuel efficency among other things I would do the 60e
__________________
Call 888-744-6542
Old 03-05-2009, 08:19 PM
It's shifts are not snappy. What do you guys do to them to make them snap and work right?
Quick Reply: Transmission experts I think I got my first problem
