LS2 timing chain
Old 03-01-2009, 06:08 AM
01 Trans-Am WS6's Avatar
Default LS2 timing chain
I posted a thread earlier about a question on my timing chain, since everything is already apart for the cam I might aswell replace the chain. I think I am going to go with an LS2 chain, however my question is, last night I went to the local parts store (Advanced Auto Parts) and asked them to look up a timing chain for me, not for my 5.7L, but one from lets say an 06 GTO since that has the LS2. For some reason, they do not have anything for that car, but do have a timing gear/chain from an 06 Corvette which also has the LS2 correct? My question is, for the price he said the timing chain and gears were $41 and the chain itself was $20....now is it just me or don't they usually run around $40? The price difference caught me off gaurd so I didn't order it and wanted to hear from you guys first, a timing chain from an 06 Vette should be good right?
Old 03-01-2009, 06:43 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Hit up Scoggin Dickey
Old 03-01-2009, 07:53 AM
vettenuts's Avatar
I would get it straight from a GM parts vendor, at least then it is a known quantity.
Old 03-01-2009, 08:08 AM
vsocks1's Avatar
^^^ I agree, I would get it from GM so the quality is known. Another option is one of the vendors that sell genuine GM parts. Not sure what you might get at the local autoparts store...not worth the risk!
Old 03-01-2009, 09:05 AM
405HP_Z06's Avatar
What brand did they quote? If it's Cloyes your good.
Old 03-01-2009, 09:10 AM
forcd ind's Avatar
i have a new LS2 GM gears and chain, tried it in 2 diff LQ4's, thought it was on the loose side, went with a doubleroller-do they tend to be on the loose side?
Old 03-01-2009, 10:16 AM
01ssreda4's Avatar
^^^my ls2 chain and gears was snug and fit perfect...
Old 03-01-2009, 11:24 AM
1998Z28LOADED's Avatar
Not sure but I got on Texas speeds website, ordered the set and had it in two days. I know it's right and I know it's quality. JMO
Old 03-01-2009, 11:51 AM
stevied916's Avatar
yank has them for 40
Old 03-01-2009, 03:32 PM
Thanks guys, the 06 Corvette does have the LS2 in it though right?
Old 03-01-2009, 05:42 PM
405HP_Z06's Avatar
Yes
Old 03-01-2009, 09:00 PM
Originally Posted by 405HP_Z06
Yes
Thanks!
LS2 chain ordered!
Old 03-01-2009, 11:35 PM
01cherryreds10's Avatar
Would it be worth it to replace it if the front cover was off, even on a stock or near stock application?
Old 03-01-2009, 11:38 PM
kidcamaro98's Avatar
I went to Napa and got mine...cost $56 out the door only cause I had to order it and it was 10$ freight charge...
I told them it was for a 06 Vette.
Quick Reply: LS2 timing chain
