Drag Racing Tech
Help with aerospace rear drag brakes
Old 03-01-2009, 08:44 AM
rmata's Avatar
Default Help with aerospace rear drag brakes
I know some of you guys who frequent this section must have some experience with these brakes. I was trying to install these last night but ran into some trouble. The rotors hit the mounting plates when they're all the way in. Can someone tell me what I might be doing wrong? Am I suppose to shim it out?
Old 03-01-2009, 10:30 AM
ATwelveSec02Z28's Avatar
holy ****.... Funny thing is I just had this happen to me yesterday
Appears that the rotor hats are wrong for the axle offset. Im giving Aerospace a call tomorrow. If you call be sure to have all your measurements handy.
Old 03-01-2009, 10:42 AM
kp
kp's Avatar
I never used the aerospace brakes but when you use the strange brakes on a 9" you have to use ~.100 spacers in the housing to space the axles out a little. Madman and SJM sells them.
Old 03-01-2009, 11:27 AM
TJ
TJ's Avatar
buddy of mine had the same issue. you need a spacer to keep the axle from walking.
he had a .125 spacer made.
Old 03-01-2009, 12:02 PM
jermzz's Avatar
+1 aftermarket rears need the spacer. I have one too for my strange brakes.
Old 03-01-2009, 12:03 PM
yrlosing's Avatar
sounds like a manufacturing problem! i have the wiilwood kit and the hat fit perfect?
i would give aerospace a call and make them fix it! nothing worse then spending a lot of coin and it not working.
Old 03-01-2009, 12:15 PM
Race your car!
JL ws-6's Avatar
There's a spacer that you have to use. Burkhart sold me teh spacer when I bought mine, and I didn't have that problem.
Old 03-01-2009, 12:17 PM
calongo_SS's Avatar
Boy that's got to be frustrating.
Looks like you're up to no good Ruben. Getting ready for the street car challenge?
Old 03-01-2009, 12:19 PM
yrlosing's Avatar
so they use a universal hat to fit a couple of applications, and then give you a "shimm" to make it work on your car!
i guess quality and workmanship is not alive in america!
Old 03-01-2009, 12:26 PM
Race your car!
JL ws-6's Avatar
I had absolutely no problem with my aerospace brakes. They went on the car easy, ya put a spacer in the housing, big deal, take it apart, call burkhart and get the shim you need, it's not that big a deal. Takes no time to put the spacer on, just slide the axle out, put the spacer in the housing, and put it back together. Simple.
Old 03-01-2009, 12:38 PM
TS6
TS6's Avatar
Dude....shut up.
Old 03-01-2009, 12:39 PM
ssick1's Avatar
lol!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!
Old 03-01-2009, 01:27 PM
TJ
TJ's Avatar
OMG, its AFTERMARKET PART!
things need to be modified sometimes.
its all apart of going fast.
Old 03-01-2009, 01:40 PM
3stgstocker's Avatar
get strange thier ***** high but works. ive used aerospace on f bodys and mustangs and thier **** never works
Old 03-01-2009, 01:43 PM
rmata's Avatar
I got the spacer from Burkhart as well as the lines. I'll go take another look at before I head back home.
Old 03-01-2009, 01:46 PM
rmata's Avatar
Nah, I'm not gonna compete in that. I do want to make it to the TX2K9 though. I'm only going to have one more weekend off before the event though, and I still have a few things I need install. It's very frustrating, lol
Old 03-01-2009, 02:32 PM
How thick are the spacers? I just did some measurements and my offset is pretty dang close to the 2.750" listed by aerospace when my axles are pulled out tight onto the retaining plate.
It seems to me the spacers are so that the axle has less play in it from where the bearing hits the retainer to when the bearing hits the inner edge of the housing end.
JL if it isnt tooo much of a pain in the ***, could you measure the rotor hat depth with or without the steel rotor?
Mine seem to need about 0.25" to fit right
Under Rear Brake Kit doesnt fit
http://www.aerospacecomponents.com/i...d=43&Itemid=41
Old 03-01-2009, 03:54 PM
NHRAFORMULA00's Avatar
I have the same brakes on a Strange 12 bolt and the rotors are 1/8 inch from the backing plate.I see you have a Moser 9 inch,my bet is your axle flange is a tad wider or the axle itself is slightly closer to the backing plate,making for no clearance.Your gonna have to space out your axles to get the correct clearance.Yo might get away with spacing out the axle with a bearing spacer,Or you might have to pull out the axles and have a longer locking ring installed to space everythig out further.
Old 03-01-2009, 09:11 PM
yrlosing's Avatar
Originally Posted by TS6
Dude....shut up.
go **** yourself!!
i believe when i pay good money for new parts, they should have already been tested and shouldn't have to be "modified" to work! a little tweak, yes. but this is a obvious design flaw!
i guess some of us belive in getting what you pay for!
Old 03-01-2009, 09:52 PM
TS6
TS6's Avatar
go **** yourself!!
Easy killer. You have to realize that there is no way for something like aftermarket drag brakes going on an aftermarket rear end to fit perfect every time. Seriously, think about it. We're not talking about being an inch off here, rather a fraction of an inch. Something as simple as a builder pressing a bearing on an extra .100 of an inch would **** this up.
I believe manufacturers think that if you have a car at this level that you should know how to adjust small **** accordingly. Its called fabrication, and I promise you every fast car has some level of it done.
Quick Reply: Help with aerospace rear drag brakes
