Car feels down on power... help
Well I went to the track yesterday and even though the car was running 9.0s and trapping 155mph. It felt like a slug from 6300rpms on. I dunno if I am getting valve float, don't have enough cam, am lifting the heads or what. The car looks like it is picking up RPM pretty quick but something isn't right. I am running the same ETs on 18psi that I was running on 14psi.
I dunno I am more than frustrated at this point. 3 outings going 9.0s and no matter what we change the car isn't going any faster. I am usually pretty easy going but this is beginning to tear away at me. The car is parked in my garage and not coming out for a week or so.
Anyways if you have any suggestions let me know.
I'm getting an AMS 1000 this week to control the boost a bit better also.
About 50 passes. I just looked at my logs from BS3 and for some odd reason i am between 6600 and 6900 RPMs for 3 seconds in 3rd gear. This is where the car feels like it is making no power! The rest of the RPM/gears feel great. It's just when I shift to 3rd the car will make no power. We are going to check the springs this week. It was fine the last time it was on the dyno, but I am thinking this is a new issue that just started.
i would make sure your not dropping fuel pressure. what kind of exhaust do u have going after the turbo??? ignition holding up??
i would not get hung up on this. this sounds normal.
Either the fuel pressure is falling, or you have some valve float problems. Those turbos on that motor are good for another 500-700rwhp more then what those mph #'s are indicating.
