need 60 ft help
need 60 ft help
just got my bmr ta lca sfc lowering springs and panhard rod but still cant get my 60 ft under 1.9. its a stock rear with 2.73 and on mt et street's. is it the gears the track or something im doing. I've tried launching from 1200 to 3000 with no change.
Better 60' times
Your lowering springs aren't doing you any favors. The lower control arms need some angle to do their job and lowering springs reduce that angle. Try some weld on or bold on lower control arm relocation brackets. You'll get the angle back on the LCA's and improve traction. Could also unhook the front sway bar or remove it and use something like the HAL QA1 "R" series front shocks to help you with some weight transfer.
I've got an 02 Heads/Cam very similar to your setup cutting 1.59 sixty foots.
i would go with the relocation brackets. Spohn used to make the best for the money. also check the position of the tires before you put the brackets on . Some people i have read said there tires where not centered after the brackets i have put many sets on and have never seen it . I would pull a tape on it before just to see.
