rear tail light panel 'Berger' look
I painted a bought rear tail light panel silver . I am still awaiting the rear CAMARO black fill in deacls to arrive . Here is the picture in the meantime...
http://community.webshots.com/photo/...94652800DQoiQJ
Re: rear tail light panel 'Berger' look
yes the bowtie is going to be painted black actualy, good eye it is low The way I went about painting it,is first find a used one so if you don't like it you can go back to stock ! Then wet sand the piece with 1500 wet sandpaper . After that clean it with dish soap to remove any grease . Then wipe it down with acetone for final cleaning .
I went to Pep Boys and bought flexible bumper primer(gray) and paint(silver metallic)along with clear coat . I applied two coats of primer,two coats of silver and two coats of clear . The emblems are retachable if you get all adhesive off ,then reapply spray adhesive . Hold the emblems in place with masking tape to act as a clamp .
Members I saw your interst in the rear 'Berger'tail light panel. I am selling them, color of your choice, with emblems(SS or Z28)along with rear fill in letters of your choice. These are OE GM panels primed, painted and clear coated . I am selling them for $225 shipped .
Jimmy Russ
Jimmy Russ
