B&M Magnum Grip Pro Stick Shifters with electrical shfiter soleniod!
i've just recevied my B&M Magnum Grip Pro Stick Shifters (B&M 81040 ) and Shifnoid Electric Shifter Solenoid Kits (Shifnoid SN5057 )..and i couldn't use the Solenoid in my TH400,,as it's only shift from 1-2 then there is a Lock to 3rd gear in the shifter( that sould be pressed manualy to unlock it)! i don't know if there is any thing possible to make the Solenoid shift from 2-3 using the Magnum grip pro stick shifter??
thank you in Advance
