Turbo questions
Old 03-02-2009, 02:56 PM
SNEAKYPETE's Avatar
Default Turbo questions
I am building 1972 2wd blazer that I am putting a 02 firebird LS1 with t-56, I plan on building a turbo kit and have read that a Z06 cam, springs, 8.1L injectors, is a great way to go, Where can I buy the cam from? Also are the stock head bolts good enough for the 500hp I am shooting for? I only want to do this once.
Old 03-02-2009, 03:08 PM
NemeSS's Avatar
z06 works excellent with turbo engines, cam can be found from SDPC along with springs, seals and pushrods. ARP bolts would do a better job than the stock tty bolts. also the LS9 head gaskets were designed for psi, so u might want to look into using them as well, and they will work with your motor.
