pcv and vacume line on valve cover
im finishing up my project and bought the engine by itself. so the pcv on the driverside and nipple on the rear of the pass side valve cover dont have ne thing going to them. where do they get routed to? anyone have a diagram? ive been searching and it says that you should not just put breathers on them.
engine is out of an 01 ls1
What kind of PCV setup are you running?? An old style LS1 setup, or the newer LS6/L92 that has the PCV system integrated into the valley cover??
it has a ls6 intake manifold. when i bought the engine where the pcv was supposed to be it was just empty. so your saying i can just run a line from the pcv to the breather nipple on the pass side? the car runs and idles fine with the 2 breathers on in. just dont want to damage anything.
