another ignition problem.
Old 03-02-2009, 04:01 PM
93lt1M6z's Avatar
Default another ignition problem.
well i just finished my plugs and wires on friday night. everything was fine until sunday night. while driving it felt like a miss under light loads. thismorning at work scanned it and had a p0300 multimiss. i havn't looked at misfire data yet, or had it in the air....but i am suspecting i burnt a wire. i used MSD 8.5 wires and forgot to change the coil wire. any chance that could be causing my problems?
Old 03-02-2009, 04:04 PM
CptMidway's Avatar
Most likely. Either that or a plug wire isn't completely connected to the plug.
Old 03-02-2009, 06:39 PM
lifeisgood's Avatar
whats your mods? headers? id say burnt wire or plug loose
Old 03-02-2009, 06:44 PM
ss.slp.ls1's Avatar
Check all of your wires thoroughly. Replace the coil wire. Test the coil.
Old 03-03-2009, 06:40 AM
93lt1M6z's Avatar
i replaced the coil wire last night...didn't change anything. i have hooker longtubes and i know my number 5 was close...so i think thats my problem. i have spare wires so ill look at it tonight and check it.
Old 03-03-2009, 04:41 PM
93lt1M6z's Avatar
well #5 was burnt up. stupid headers. so i wrap the wire in some extra header wrap and wraped the header more and put another wire on. luckily i have spares. see what happens
Old 03-03-2009, 04:44 PM
ss.slp.ls1's Avatar
It's funny how one or two wires can f*ck everything up...
Old 03-03-2009, 05:19 PM
WARDOG's Avatar
Default wires
+2 on that one brother. I didn't run my wires through the separator by the opti on the passenger side and the damn pulley got 2 of my wires and burned 1. I recomend you get some Jegs 8.5 mm wires man , pretty good quality for $40 dllrs or $30 for the 8mm . I run them in my 97 ws6 . Good luck replacing them and best of all take you time and do it once .
Heres the link to the wire set:
http://www.jegs.com/webapp/wcs/store...-1&showValue=3
Old 03-03-2009, 05:27 PM
93lt1M6z's Avatar
yea man its crazy,.....oh so annoying
haha
Old 03-03-2009, 05:28 PM
lifeisgood's Avatar
thats why i said burnt wire. ive had same experience
Quick Reply: another ignition problem.
