water in oil?
Could be any of the following:
A. You have been driving your car on short trips in cool weather, resulting in a builtup of moisture in the oil cap.
B. Your PCV system is not functioning properly, causing blowby gasses and oil sludge to build up in your crankcase.
C. You have a blown head gasket. Check the dipstick and see if you have the same sludge like deposits on it as well.
ok guys thanks. i did leave it for a week at a mechanic in which he never touched the car. it was cold and rainny. the dipstick was clean. also the coolant is green.
You probably don't need anything except a good drive. Moisture in the oil cap is common. If the dipstick and and coolant look good then it's just condensation forming in the cap. Drive it and enjoy.
