Cam or Stall Converter
Old 03-02-2009, 05:04 PM
Bishimus's Avatar
Default Cam or Stall Converter
Well I would like to know what would be best for my next mod eithor a cam or stall converter. I can't afford both at the time and I would like to know which one would be the best for my application. My current setup is in my sig.
I want my car to continue to be streetable - it's my daily driver and I never race it at the strip, but i'll take any mod that will boost my hp.
From what i've been researching a tr224 114LSA & 3200 stall would be best for my car???
Old 03-02-2009, 05:06 PM
streetassasin's Avatar
a converter would be your best bet, you wont gain any hp, you might actually lose some but it is a deff kick in the ***
Old 03-02-2009, 05:09 PM
DaveX's Avatar
Best cam/stall combo depends on what you want out of the car. The 224 is a great all around street cam. The stall won't give you any more HP but it will make the car alot more fun to drive and is (imo) required before installing a cam 224 or larger. I would do the stall now, just research your cam choice now so you can go ahead and get a stall that will work well with it later once you have the funds for a cam.
Old 03-02-2009, 05:10 PM
Bishimus's Avatar
Also it would be ok to just go for a small cam and still get a HP gain after a tune without the new heads, stall converter, or gears right??? Or is all or any of those 3 mods absolutely necessary when changing the cam.
Old 03-02-2009, 05:14 PM
FiFdYnUtz's Avatar
definitely get the stall first, its a must when running a good sized cam anyway...
Old 03-02-2009, 05:20 PM
Bishimus's Avatar
ok thanks guys - I will most likely go with a 3200 once i find the right price for one
Old 03-02-2009, 05:23 PM
A GOOD stall will be expensive, mine was $725+tax
I would only go with CircleD, Yank or Vig.
Old 03-02-2009, 07:03 PM
SOMbitch's Avatar
There are other good ones but I agree on his basic point. If you "cheap out" it will cost you in the long run run when the "budget" vertor takes the rest of the tranny with it.
"budget" headers are just fine but "budget" vertors are not......
Old 03-02-2009, 08:58 PM
tording99Z28's Avatar
I vote stall too. Will make the car so much more fun to drive and give it a serious kick in the pants.
Old 03-02-2009, 09:16 PM
Detoxx03's Avatar
If you can only do one now i'd do the converter first
Old 03-02-2009, 09:17 PM
Droptopws6's Avatar
Stall, Stall, Stall !
Old 03-02-2009, 09:22 PM
Mean87SS's Avatar
stall.
Old 03-02-2009, 09:25 PM
99T/AMAN's Avatar
i did the convertor first and love my Yank!!!
Old 03-02-2009, 09:59 PM
01ssreda4's Avatar
im running a tr224 and Edge 3200 and it is an awesome combo. not the fastest thing out there but it impresses guys that run bigger cams when they ride shotgun....
Old 03-03-2009, 04:47 PM
Bishimus's Avatar
Well this is exactly what i'm looking for - thanks for all the help. :]
Old 03-03-2009, 04:51 PM
TXZ28LS1's Avatar
definitely do the stall. i have a vig 3200 and its perfect for a daily driver. might be able to step up to a bigger stall. but my car is just a fun little street car.
Old 03-03-2009, 04:56 PM
1999Transamman's Avatar
Stall for sure. Definitly gonna feel it more than a cam. Go with a Vig if you can afford it. I had a Fuddle and it took a **** on me. Spent the money and got the Vig, no problems since.
Old 03-03-2009, 05:10 PM
rusty2198's Avatar
Stall first most defiantly. I have a vig 3500 and it made my car feel like a totally different car. Not to loose on the street almost feels stock when you get used to it. I put in pacesetter LT's and the vig at the same time and knocked 8 tenths off my 1/4 ET I do believe the most gain was from the converter. Should be more than 8 tenths due to traction problems that I never had befor
Old 03-03-2009, 06:10 PM
Kingc8r's Avatar
Stall first then a cam...
Old 03-03-2009, 06:30 PM
4.6what's Avatar
STALL!! but like they said dont skimp on it. first time i bought a 2800 Dacco non lockup that costed 250 and it didnt even make it 10k before it took the new tranny out. i bought an Edge 3000 and loved it. stall first then cam
