Shift Points?
LS1Tech Sponsor
That varies alot from car to car and transmission to transmission, Converter size comes into play. Rear ratio, Power band and power of car. You might get a baseline from someone with similar mods and trans in there car but dialing it all in will be hands on.
__________________
The points with the 150 shot are probably gonna have to be commanded a little earlier than with the NA setup. The nitrous will make the rpm's climb faster and there is always a little bit of a delay between the time the shift is commanded and the time it happens. Its just the nature of electronic transmissions.
