F.A.S.T Fuel rail problem
well i installed fast fuel rails on my car, and now when i start it it runs fine for a few seconds, when i get in my car to take off or give it gas it kind of sputters/misses out, it is blinking a check engine light and it goes off when i let the car idle down.... Im trying to find out if i need to upgrade my fuel pump or what not to run these fuel rails, or what i need to do.....
Just replacing fuel rails is not going to change how it runs. You have a connector or plug wire not seated all the way. you need to figure out which cyls are not firing and check all connections. Or you got some junk in one of the injectors when replacing them.
Nate
Nate
