my deck and windows go out wild im drivimg
i have a camaro 2000 ss and for some reason im having some electrical problems.. wheni start the car sometimes the deck doesnt turn on and if the decks off them both of my windows wont work. but if i turn of the car and keep putting the switch on sometimes it turn on and i can open the windows..it does it a lot. it also turns off when im driving and drive over a bump of run over something. but it also turns on when i drive over bumps. so the windows and the deck go off at the same time..i check the fuses their good and i chechk the ground and its good any ideas?
It is the body control module (BCM). There are a few of the connections that come loose and cause this to happen. There is a thread around here somewhere that has pics on which ones they are and how to fix it. If you are comfortable working with electrical components, it can be fixed. If not, you have to replace the BCM.
