Corvette Performance - Running Rear o2s in the Front bung
06X6spdGTO
03-03-2009, 01:04 AM
My tuner has informed me that my front o2 sensors cant perform up to par. he said i need to look at running my REAR o2 sensors in the front locations due to the rear sensor being able to run hotter. has anyone done this???
FWIW i have Kooks 1 7/8LTs.
~JOSHUA
03-03-2009, 02:42 PM
Actually, they are the same sensor.
The only difference is the longer cord/cable on the rears.
You can run rears on the front, but it will have no bearing on heat... same thing just with extra cord left over.
06X6spdGTO
03-03-2009, 03:08 PM
so the plug-ins on the o2s are exactly the same???
gold98Z28
03-03-2009, 03:24 PM
yes the plugs are exactly the same, i know some cars call for the same sensor in all four and some call for a differant one, some may have a better heater than others, but they all work.
06X6spdGTO
03-03-2009, 03:36 PM
good becuz i currently have the LG wiring harness for extending the front wires, now i just need a better (Hotter) sensor since the fronts a moved farther from the Exhaust port.
FourG63 97GST
03-03-2009, 07:59 PM
I run rear O2 sensors in my front bungs on my longtubes, the connectors are different, but if you have the LG adapters you're ok
06X6spdGTO
03-03-2009, 08:02 PM
ok so the connectors from front to rear are different! Thanks
gold98Z28
03-03-2009, 11:55 PM
hum... maybe the vettes have differant plugs on them..... what year is the car? i know the fbodys all four are exactly the same. are the ls1 vette's differant front to back too, or just later ones? i stand corrrected
06X6spdGTO
03-04-2009, 12:21 PM
2001 ls6 z06
SBcamaro
03-04-2009, 03:42 PM
the plugs are differant in frount & rears the 02 sensors are the same
Rossi396
03-04-2009, 03:47 PM
Are you getting codes after the header install?
06X6spdGTO
03-04-2009, 04:07 PM
no im not getting codes my tuner just had to shut off my LTFT for both banks due to trouble tuning with the o2s not running hot enough
LS1C5Vette
03-04-2009, 07:25 PM
Yea the plus are different, I run my rears in the front
pewter2165
03-04-2009, 08:15 PM
So is there a hotter o2 sensor?
SBcamaro
03-04-2009, 08:41 PM
Yea the plus are different, I run my rears in the frontso are you runing cats
06X6spdGTO
03-05-2009, 08:18 AM
nope, no cats. ls1c5vette with the plugs being different how did you connect them??
ls1290
03-05-2009, 08:43 AM
WTF?!?!? First I am not sure that is even possible. Second, why in the hell would you want to do that. In closed loop mode, the LTFT are very important in determining the amount of fuel to be delivered. Has your tuner worked on a EFI car before.
gold98Z28
03-05-2009, 10:02 AM
um... not only very possible but very common. short trims are the norm for tuning. much faster and better than waisting a tank of gas waiting for long trims to settle in and average out. if the tune is inline the long trims are not needed. most turn them back on after tuning but some dont, ive had mine turned off for over a year. they are only used as a stored look up table, short trims are your instant fueling.
06X6spdGTO
03-05-2009, 03:00 PM
My tuner has been tuning cars for about 8yrs now. Its Dyno Dan owner of Dynosport in Lincoln.
06X6spdGTO
03-05-2009, 03:02 PM
http://www.dynosport.com/
Heres his website.
ChevyWeatherman
03-06-2009, 09:40 AM
I am friends with one of the owners of HP Tuners. He had LTFT's turned off in my car when I bought it from him, so I'll take a guess that it isn't that big of an issue.:lol:
LS1C5Vette
03-19-2009, 01:02 PM
No cats
Bought adapters for $50 from I forget where
VeroWing
03-24-2009, 06:50 PM
I'm new here, and don't want to be a smart guy, but, from everything that I've ever been told regarding C5 Corvettes is, that the rear o2 sensors have a hotter heater than the fronts. That is why many people recommend placing rear o2s in front when adding headers. Again, I'm no authority, but I have been advised of this by a few well learned C5 people. Mike
VeroWing
03-24-2009, 08:38 PM
Just found this on another thread info from a Bosch tech:
'He did shed some light on some of the issues at hand. First off, he said that the heaters in the front sensor are the same as the heaters in the Corvette rear. However, there is a difference in the baffling of the sensors and that the baffling does effect the temp they run at, and due to this difference he thought that the rear Corvette sensors, when used as fronts, would be at an advantage over the fronts.'
So I stand corrected, sensors appear to be the same, with different baffling.
