315s on all 4 corners
Old 03-03-2009, 09:59 AM
Dskeet6's Avatar
Default 315s on all 4 corners
I have two pairs of 17x11 +50mm zr1s with 315 sumitomos...... I tried searching but couldnt find much
i know people have done this before.... just want to know if there are any rubbing issues... I dont want to end up grinding on my front fender
anyone!
Old 03-03-2009, 10:07 AM
2QUIK4U's Avatar
Im pretty sure you have to have custom offset wheels to clear in the front. If I were you I would contact Sam Strano. I know he runs 315's all the way around.
Old 03-03-2009, 10:55 AM
STEEPSS's Avatar
yeah, i'm sure the offset would have to be different. The Dick Harrell cars ran 315's all around also
Old 03-03-2009, 11:35 AM
02NBMWS6's Avatar
Those will be fine, you will just need to run a small spacer in the front, (1/8" inch I believe) and do a slight bit of grinding to the spindle. They may bulge from the fenderwell just a slight bit though. I just recently saw a car with 315s at all four and thats what he had to do. I just did a 18x10.5 rim up front with a 56mm offset and it worked perfectly with no modifications needed either.
Old 03-03-2009, 02:04 PM
02nwZ28's Avatar
That's a pretty popular setup for alot of the road race guys as far as I know, but I'd get in contact with strano to make sure you wont run into issues
Old 03-03-2009, 03:11 PM
Customizing Director
MadIceV8's Avatar
Since they have +50 offset I think you'll be fine with the rim clearance. I'd be worried about the tire rubbing on any 45* or more turn in the fenders. A spacer would also make this worse. You may be able to flex in the plastic fender walls to gain more clearance.
