Question for you guys with bbk shorties!!
HOW THE HELL DO YOU CHANGE YOUR SPARK PLUGS!!
Lol. man I can't get to the plug in the very back on the drivers side. I havn't even looked at the pass. side yet. do yall have any tips or tricks?? Im in dire need of a plug change and i can't get all of the old ones out.
HELP!!!
HELP!!!
take a 5 sided plug socket, cut off the ratchet end about 1/2 way and remove 1 of the 5 sides from the socket. That way you can put in on the plug from the side and use a box end wrench to losen THEN remove socket and unscrew plug by hand
or you can buy something from www.headersockets.com
Yes, the back drivers side needs a shorty plug socket to get to it...
Ohter than that the rest are all pretty easy... I can do plugs in about 40 minutes total...
Good luck.
Good luck.
