VHT Flameproof Coating
http://www.vhtpaint.com/flameproof.html
I coated my turbo manifolds with this stuff. I did about 3-4 cans for the downpipes/manifolds all together. Now i just read a thread about heat wrap w/ sum type of insulating spray-on tar ( for lack of a better word ) SUm say its good sum say its bad as always. All this talk about moisture, and the ability of the exhaust piping holding heat, being relative to the diameter of the piping etc etc.
Any in sight would be awesome. Mostly im after sumone who has used this VHT sh*t b4... thanx
I took apart my turbo kit from last yr. It was all painted in high temp, most of it faded off.
Right now all the hot parts getting sand blasted. Then im going to repaint. Then im going to wrap it in Dei header wrap, and also use the Dei silicone coating. Header wrap will hold in moisture, and cause some rust. It also will hold in heat, and help spool up.
The same stuff gets said about turbo blankets. Im gonna give it a try, and see what happens.
Chris
Chris
so there is pretty much no way around the moisture ...im just trying to figure out if this VHT is worth a damn or did i waste my time and money. Im also looking for suitable alternatives that are proven successful ... thanx
i just had mine recoated. the up pipe was jet hot coated. the down pipe was painted with high temp paint. both were wrapped. when removing the wrap the paint was gone. the exhaust was a rust color. the jet hot coated up pipe was still perfect. also this was about 12 track passes and about 50 miles on the street. get it coated.
Yeah, no need to pay big bucks for Jet Hot when that same Ceramicoat process is available at any good coater/plater. The silver is good to ~1400 and the grey and black are good to ~1800. Prices are about 50-75% of what Jet Hot charges, plus you don't have to ship your stuff all the way there and back.
Just remember to protect the coating during installation because it needs to cure under heat for a couple hours of runtime before it is really scratch resistant. After that it is tough stuff.
Jim
PS I used the grey on my blower pipes to/from the FMIC if anyone wants pix of what it looks like.
Jim
