What do you guys think about this build for a Daily Driver
I want something with at least 400 hp but has to be reliable i was gonna get roller rockers (should i go 1.5 or 1.6), get the heads rebuild at a machine shop(what exactly should i have him do to the heads), do a mild cam (cause i have to pass emisions ), and then get it bored out 30 over and should i just use the stock crank and rods
so what do you guys think i will pull with this setup and is there anything else that i will need with it
thanks
thanks
-LLOYD ELLIOTT LE2 CAM
-LLOYD ELLIOTT LE2 HEADS
-LLOYD ELLIOTT PORTED INTAKE MANIFOLD
-LONG TUBE HEADERS (1 7/8)
-EXHAUST
-K/N CAI
-58MM THROTTLE BODY
-160 DEG THERMOSTAT
-37# INJECTORS
-THROTTLE BODY BYPASS KIT
-TICKFLOW ELBOW
-PULLEY'S
-MEZIERE HEAVY DUTY ELECTRIC WATER PUMP
-1.6 ROCKERS
-ALUMINUM DRIVESHAFT
i was thinking of doing the le2 cam and heads combo or the advanced induction, what will the aluminum driveshaft do(i know it saves weight but why would i need it) and what does the throttle body bypass kit do, and with an electric water pump do you have to flip a switch to turn it on everytime you start it because this is an everyday driver and could become a pain
i was thinking of doing the le2 cam and heads combo or the advanced induction, what will the aluminum driveshaft do and what does the throttle body bypass kit do, and with an electric water pump do you have to flip a switch to turn it on everytime you start it because this is an everyday driver and could become a pain
Aluminum driveshaft decreases rotating mass - good for a few HP to the wheels (weaker than the stock steel shaft). Also has been known to decrease high speed vibrations (known as "vibeshaft.")
The throttle body bypass bypasses coolant flowing through the lower part of the throttle body, decreasing intake charge temps. Worth a few HP as well.
Electric water pumps are commonly switched to a switched 12V+ source. This means that whenever the key is on, the pump is on.
