Northwest Members - any ls1 swapped cars in wa?
firechicken76
03-04-2009, 12:03 AM
third gens, rx-7's, 240's? theres a green delta 88 that goes to local shows around here thats really nice.
There's a yellow 3rd gen RX-7 here on Whidbey. It has a stock '02 LS1 with a few bolt ons. He has a nice cam for it, but he's been too lazy to buy the supporting pieces. I've driven it a few times. It scoots pretty decent for stock being that it only weighs 2800lbs and the stock 4.10 gears out back.
firechicken76
03-04-2009, 01:10 AM
sounds about like mine, but mine weighs about 3300 :( still lighter than a 4th gen though, ive got 4.11's and an 02 ls1 with bolt ons, ill be doing a cam eventually too :)
Mikey 97Z M6
03-04-2009, 09:20 AM
My 97 used to have an LT1. Used to...... :D
Mike
firechicken76
03-04-2009, 11:59 AM
Mike
but not any more hehe.
ive seen some on craigslist before, a gen 2 rx-7 with an ls1/auto, recently a jeep with an ls1, saw a 240 that said it had an ls1, but couldnt get any straight answers out of the seller grrrr
AndreS
03-06-2009, 05:20 AM
88 RX7 here... Sammamish, WA. it' not perfect, but that was the point... small dings & scratches, quiet & all under the hood. I don't take it out much, had it to the track a couple times last year... 12.03 @113 so far.
Ackattack1
03-06-2009, 09:57 AM
There's a guy who gets on here sometime with a C-3 vette with an LS1
JohnB? has a MonteCarlo with an LS7 (I think he had an LS1 and LS6 in it also)
I'm putting one in my 68 Chevy pickup.....not wired up yet....waiting on paint.
firechicken76
03-06-2009, 11:32 AM
auto or t-56? is it the one i saw for sale on craigs list awhile back? pics?
iansane
03-06-2009, 07:53 PM
Getting close to firing off my 91 TA vert with a 5.3/t56.
firechicken76
03-06-2009, 09:23 PM
hell yea! what mods?
iansane
03-06-2009, 09:55 PM
Really none so far. LS6 intake and hawks headers. Just an upgrade from the HSR 305 that was in there for now. I'll wait 'till I get it running to start modding.
firechicken76
03-06-2009, 10:16 PM
ive got a set of hawks headers ready to go in, might do a cam after that, whats your curb weight?
AndreS
03-07-2009, 12:53 AM
Auto- performabuilt stage 2, w/ 3500 stall, using a Hurst quarterstick shifter. It's a base model w/ sunroof, Al hood, manual steering, & no AC. mods include suspension work(currently set up more for the strip), 5-lug hubs, turbo diff, shorty headers, X-pipe, & ported TB. I hope to have time/cash to do some more mods this spring/summer.... haven't put it up for sale.
pics: (has stock 5-lug wheels on it now, and a few other minor changes for function.)
http://i102.photobucket.com/albums/m111/AndreS123_03/derby-2.jpg
http://i102.photobucket.com/albums/m111/AndreS123_03/derby-1.jpg
http://i102.photobucket.com/albums/m111/AndreS123_03/derby.jpg
Mcheap
03-07-2009, 06:10 AM
A while back there was a gunmetal FC with a LS1 in it for sale locally.
iansane
03-07-2009, 10:34 AM
Absolutely no idea. :D It was 3800lbs w/ gas and driver before the swap. I dropped it on the ground and rolled it back a forth a couple times to see it settle but I still have a good 3-4" fender gap where before I couldn't stuff more than a thumb in.
firechicken76
03-07-2009, 01:22 PM
yea, so sounds like you lost some weight, those arent aluminum are they?
about the header install... i was wondering how hard that is to do, ive been putting it off because it looks time consuming, i think im going to install them, take out the A.I.R. pump, cut out the stock Y pipe, have a custom y pipe made (No cats), and exit into a 4" electric cutout
firechicken76
03-07-2009, 01:25 PM
very nice! are those lighter than a 3rd gen? how strong are the rear ends in them?
iansane
03-07-2009, 01:32 PM
yea, so sounds like you lost some weight, those arent aluminum are they? about the header install... i was wondering how hard that is to do, ive been putting it off because it looks time consuming, i think im going to install them, take out the A.I.R. pump, cut out the stock Y pipe, have a custom y pipe made (No cats), and exit into a 4" electric cutout
Iron heads, Al block. But still loads lighter than iron block, iron heads, al intake 305.
The headers were cake. My old hedmen LTs required denting and lifting of the motor to get in correctly. These Hawks fit amazingly well in the engine bay. I have a non-AC heater box though, don't know if there is interference there. My only qualm with the headers is the collectors sit way to close to the frame rails for me. I would've liked it if they tucked closer to the trans. But what can ya do.
firechicken76
03-07-2009, 01:35 PM
what did you use for a trans crossmember? ive got a spohn now, but also have one that the previous owner bought that is in a "W" shape meant for pipes to go under for more clearance i guess, i have A/C, but dont need it, i need to clean my engine bay up a little.
iansane
03-07-2009, 02:29 PM
Originally I used the spohn one. Man that was a hideous design. It stuck so far down I scraped on EVERYTHING. I found a member on thirdgen.org "drews" that was making the double humped xmember. From what I understand he no longer makes the xmember but Skulte offers a similar one.
http://www.skulte.com/product_info.php/cPath/22/products_id/83
http://www.skulte.com/images/Longtube-T56-xmem-web.jpg
If yours is like that, I'd run it no doubt. Sell off that spohn unit so you can run the LTs straight back instead of having to cross over to the passanger side. MUCH better clearance.
firechicken76
03-07-2009, 02:51 PM
Thats the one i have, i just couldnt remember the name.
AndreS
03-08-2009, 01:01 AM
that was one of the sweetest FC's I've ever seen. it sold to a guy in a Alberta for $12k I think.
the FC is about equal in weight to the FD, depending on options, the bonus of the FC is they're dime-a-dozen, and much easier swaps (more space, cheaper kits). the FC can loose a bunch of weight depending on what you want to give up, I think mine's about 2600# some I've read about being as low as 2200#.
the stock NA 7" rear end is a weak one(though some guys run them with autos), the turbo is 8" & clutch limited slip, but the only ratios are 4.10:1 or a rare 4.33:1(sought after by the rotorheads). they can hold up to about 450 hp but not beyond it. there are a couple diff swap options(ford 8.8 IRS and other live axles) now for better gear ratios but it gets spendy fast...
fknsmshn
03-08-2009, 01:06 AM
Saw a 240 with an LS2 in it down in Auburn. From what I was told it was pretty much just a GTO with 240 body pannels. As in, swaped motor and drivetrain, even the steering wheel was outa the GTO.
chuckyssvt
03-08-2009, 03:00 AM
just finished mine..
http://www.cardomain.com/id/ChuckBlowers
check it if interested
Chuck
Crisisman
03-08-2009, 09:26 AM
I know the car your referring to. It has an LS2 and GTO seats and he even put GTO hood scoops into the hood. Very well done, and 400 rwhp.
Also, there is a fairlady Z with an LS1 that came to the Turbo Tech Dyno Day a couple years back. Also very well done.
kustomtool
03-22-2009, 11:39 PM
I am up here in Mt Vernon in process of a LS1 A4 swap into my 39 Ford sedan. My 38 w/406SBc weighed in at 2980 so I'm hoping for 2850 roundabout for this one. Just headers, cam & maybe LS6 intake to start with.
Trying to get it down to Bloods in 3 months for a tune. Anybody close to me doing any LS swapping?
Word is there's a G-body El Camino with a cammed LS1 rumbling to life on Whidbey somewhere.
firechicken76
03-23-2009, 09:14 PM
just put my lts on today!! open headers are louuuuuuuud lol
next? h/c ....and new ttop seals
