Gears & Axles - 6 lug axels in f body rear end?
View Full Version : 6 lug axels in f body rear end?
02anti_vnm
03-04-2009, 09:03 AM
Ok I searched and couldn't find anything about this so I figured I'd ask here... My buddy has a 2000 silverado he is about to put a ls6 cam and sum headers on it and also wanted to put a set of 4.10 gears in it. I told him why not just spend the extra money and buy a used f body rear end with some 4.10s already in it. The reason for that is to get rid of the one tire fryer he has at the moment. So will the rear end fit right in and can he put his axels in the f body rear end so he can keep his 6 lug?
Thanks!
9000th01ss
03-04-2009, 09:12 AM
Not even close. and a very bad idea. Why do you think people are spending $2500 to put 12 bolts and 9 inch fords into these cars?
Because the stock rear breaks. Theres even a sponsor on here working on a project so a 8.6 , like in your buddies silverado, will bolt into an f body.
You're moving in reverse.
Thanks!
STEEPSS
03-04-2009, 10:39 AM
agreed. if he's worried about breaking something, why not just put a posi in a 3/4 ton rear from a 2500 HD?
Jawsgear
03-04-2009, 11:11 AM
Just upgrade the differential with a set of 4.10 gears, Eaton Positraction, and a set of stronger axle shafts. Your done. We carry all the parts and can take care of you. Let me know if we can help you out.
Jeff
02anti_vnm
03-04-2009, 11:17 AM
Its not an issue with breaking the rear end its just guna be a 5.3 with ls6 cam headers and tune it might make 300 wheel its not an issue of breaking the rear end its an issue of having posi
Jawsgear
03-04-2009, 11:19 AM
So just upgrade to a positraction, otherwise you have to buy new axles and your gonna end up spending the same if not more moneyto put the Fbody differential in and have a weaker differential.
Jeff
dschmittie1
03-04-2009, 11:27 AM
Still not worth it. someone correct me if I am wrong but isn't the 10 bolt in the truck a larger diameter ring gear. Put a posi unit and gears in the truck rear and be done with it
Jawsgear
03-04-2009, 11:40 AM
Yes it is an 8.6 compared to a 7.6 in the Camaro/WS6.
ss1
03-04-2009, 02:13 PM
Don't those trucks have leaf springs??? Are the rear ends the same width? It would be a HUGE project, and in the end you'd still have less of a rear end than the truck came with.:barf:
Jawsgear
03-04-2009, 02:28 PM
Yes leaf spring setup on the trucks, width is different, ect ect ect.
Jeff
