DIY fuelpump hotwire?
Old 03-04-2009, 01:57 PM
pyro719's Avatar
Default DIY fuelpump hotwire?
Im going to make my own fuel pump hotwire kit. All it is is a wire from the battery to a relay and a wire from the relay to the fule pump, and a ire from relay to the old hot wire. Wich wire is the one that feeds the pump 12 volts?
Old 03-04-2009, 02:04 PM
ss.slp.ls1's Avatar
Does this help at all?
Old 03-04-2009, 04:41 PM
koolaid_kid's Avatar
You will also want a quality weatherproof fuse up close to where you connect to the alternator. It's the black two piece thing just to the left of the alternator hookup ring terminal.
Old 03-04-2009, 05:08 PM
shbox's Avatar
http://shbox.com/1/1995_pcm3.jpg
Old 03-04-2009, 07:37 PM
pyro719's Avatar
The answer is grey. Thanks Shbox.
Quick Reply: DIY fuelpump hotwire?
