least expensive good oil pump
Old 10-16-2003, 08:31 AM
blue by you's Avatar
Default least expensive good oil pump
who sells the lest expensive, yet quality oil pump? whether it be a ported LS6 one or just a real good quality pump. the cheapest one i've found so far is through TSP for 129.99 for a ported LS6 pump. thanks, Jess
Old 10-16-2003, 08:37 AM
DeVolk's Avatar
Default Re: least expensive good oil pump
Go w/the TSP ported LS6 pump!!! i had some issues over the last few months w/my 98Z28 M6 losing oil pressure....installed the TSP and im running awesome oil pressure now quality product and good results...
before TSP oil pump 37-38psi at cold idle
after 60psi at cold idle
before pump at warm idle 22psi
after at warm idle 42psi
Old 10-16-2003, 08:40 AM
jyeager's Avatar
least expensive, yet quality? OEM. There were some issues with earlier pumps, but the current pumps are great unless you have something extreme in mind.
I think the main cause of pressure problems is the o-ring seal on the pump, so be careful when installing.
Old 10-16-2003, 01:56 PM
Chicago Crew UnderBoss's Avatar
DEVOLK or ANYONE:
Can you kindly give me the phone number for TSP and what is the BEST OIL PUMP that money can buy, if i were to make a switch on my 427 C5R MTI motor, in order to get better oil pressure temps?
THANKS
Old 10-16-2003, 02:02 PM
DeVolk's Avatar
1(806)866-0734 is the # for Texas Speed and Performance....w/your combo, i think this TSP ported LS6 oil pump will do just fine...in fact, it sounds like u need it...hope this helps
Old 10-16-2003, 03:03 PM
THANKS ALOT man i appreciate it!
Old 10-16-2003, 03:56 PM
jmX
jmX's Avatar
I agree that a new GM pump if you have an early LS1 is the cheapest and best way to go, however all the pressure problems were not from the o-ring but from the releif valve sticking (unless, of course, you did a cam change and have had the stock oil pump off). It is a well known GM failure, and even dates back to 94-95 when they were first testing the LS1 in "Cormaros".
Old 10-16-2003, 04:05 PM
Trojan T/A's Avatar
Is a ported oil pump really recommended for revving to 6600-7000 rpm?
