Emissions question... drive cycle
so i went to have the car air tested today and had to jump the car to start it since its been sitting since november.. the car ran and was driven for about 2 hours before the test.. here in illinois they just do an obd2 test.. so since the battery was dead i have to go through a drive cycle so these readiness test are ready .. whats the process.. thanx in advance
Performing a GM OBD-II Driving Cycle:
Cold Start.
1. In order to be classified as a cold start the engine coolant temperature must be below 122°F (50°C) and within 11°F (6°C) of the ambient air temperature at startup. Do not leave the key on prior to the cold start or the heated oxygen sensor diagnostic may not run.
Idle.
2. The engine must be run for two and a half minutes with the air conditioner on and rear defroster on. The more electrical load you can apply the better. This will test the O2 heater, Passive Air, Purge "No Flow", Misfire and if closed loop is achieved, Fuel Trim.
Accelerate.
3. Turn off the air conditioner and all the other loads and apply half throttle until 55mph (88km/hr) is reached. During this time the Misfire, Fuel Trim, and Purge Flow diagnostics will be performed.
Hold Steady Speed.
4. Hold a steady speed of 55mph (88km/hr) for 3 minutes. During this time the O2 response, air Intrusive, EGR, Purge, Misfire, and Fuel Trim diagnostics will be performed.
Decelerate.
5. Let off the accelerator pedal. Do not shift, touch the brake or clutch. It is important to let the vehicle coast along gradually slowing down to 20 mph (32km/hr). During this time the EGR, Purge and Fuel Trim diagnostics will be performed.
Accelerate.
6. Accelerate at 3/4 throttle until 55-60mph (88-96 km/hr). This will perform the same diagnostics as in step 3.
Hold Steady Speed.
7. Hold a steady speed of 55mph (88km/hr) for five minutes. During this time, in addition to the diagnostics performed in step 4, the catalyst monitor diagnostics will be performed. If the catalyst is marginal or the battery has been disconnected, it may take 5 complete driving cycles to determine the state of the catalyst.
Decelerate.
8. This will perform the same diagnostics as in step 5. Again, don't press the clutch or brakes or shift gears.
Cold Start.
Idle.
Accelerate.
Hold Steady Speed.
Decelerate.
Accelerate.
Hold Steady Speed.
Decelerate.
