What lt1 clutch should I go with?
Old 03-05-2009, 10:03 AM
dream69's Avatar
Default What lt1 clutch should I go with?
I've got a 96 Z28 M6 that will need a new clutch soon. Any advice what is the best in performance, durability, driveability, and value for daily driver who is just beginning the modification process?
Old 03-05-2009, 10:48 AM
porksoda's Avatar
I love my Ram HDX and I just purchased a Ram HD from Scoggin Dickey. Call up Jesse at Scoggin Dickey because they are having a sale right now on Ram.
Old 03-05-2009, 10:56 AM
kinglt-1's Avatar
Ram is good for the money, so is spec. I run a spec stage 3 and it is almost smooth like the stocker. It has a lil more peddle pressure and grabs a bit more on let out. Overall has been a great clutch for 8k mi now.
Old 03-05-2009, 11:25 AM
ss.slp.ls1's Avatar
You could try a OEM clutch kit and replace the stock clutch disk with a McLeod single street/strip clutch disk.
Old 03-05-2009, 11:33 AM
Z-RATED94's Avatar
Get the A4 kind. M6's are fun to drive, but a stalled A4 takes the win almost every time at the track.
Old 03-05-2009, 11:35 AM
blackz6sp's Avatar
X2
Old 03-05-2009, 11:59 AM
ss.slp.ls1's Avatar
Old 03-05-2009, 12:01 PM
chavez885's Avatar
I have this clutch, drives smoother than stock and good holding power for cammed/bolton cars.
Old 03-05-2009, 12:04 PM
porksoda's Avatar
^^^You have the HD or the HDX? I'm looking for input on the HD on LT1's.
Old 03-05-2009, 12:06 PM
Z-RATED94's Avatar
Easy guys, I said the M6s are fun to drive. Not just really a fast way to go for most.
Old 03-05-2009, 12:09 PM
ss.slp.ls1's Avatar
Again...
Old 03-05-2009, 12:50 PM
chavez885's Avatar
I have the HDX right now, I will switch to the HD when I am ready for the bottle down the road. I am very happy with the HDX.
Old 03-05-2009, 01:18 PM
dream69's Avatar
Whats the differece between the hd and hdx? Price?
Old 03-05-2009, 01:20 PM
LM97Z's Avatar
With the prices of these going up & up, your better off just spending the 400+ on a Ram kit or others, the OEMs are at around 220.00 now, then you'll be out another 180.00-200.00 for a good street/strip disc.
Old 03-05-2009, 01:40 PM
chavez885's Avatar
375$ for 425 hp (rated) http://www.texas-speed.com/shop/item...d=366&catid=59
480$ for 600 hp (rated) http://www.byunspeed.com/product_inf...oducts_id=4890
Also, don't forget to change your rear main seal and bearings.
Old 03-05-2009, 04:32 PM
porksoda's Avatar
PM "Scoggin Dickey" for prices on Ram clutches. They have a huge sale going on.
Old 03-05-2009, 04:44 PM
Wesmanw02's Avatar
When a 4L60 can hold 600ft/lbs+ in stock form and can do anything well besides going in a straight line, please come back and let us know
OP, we had a Zoom clutch on an LT1 in the shop the past couple weeks, the guy said he was really happy with it and it looked like a really nice unit. It was very smooth and driveable for a puck style clutch. I don't know how good they are, but might be worth checking out at least.
Old 03-05-2009, 04:53 PM
bigj2717's Avatar
I just put a Ram ppwergrip hd in my car and i love it. I havent broken it in yet but so far not chatter and feels great slightly stiffer then stock but nothing too bad
Old 03-05-2009, 06:42 PM
BALLSS's Avatar
FWIW that is what I run. I bought it and the RAM from Summit. Compared them side by side...closed the box on the RAM and sent it back.
The differences on LT1 clutches is in the disc material and construction. Pressure plates are either Valeo (OEM) or clones.
With a stock set up...a "replacement" clutch from auto parts store will be fine and the cheapest route.
1st two pics = ZOOM, next 2 RAM
note the disc construction...ZOOM is a 1 piece, RAM has fingers connecting outer disc with rivits.
the ZOOM is about $50 more than the RAM
Attached Thumbnails What lt1 clutch should I go with?-lt-1-clutches-051.jpg   What lt1 clutch should I go with?-lt-1-clutches-053.jpg   What lt1 clutch should I go with?-lt-1-clutches-058.jpg   What lt1 clutch should I go with?-lt-1-clutches-055.jpg
Old 03-05-2009, 06:47 PM
Wesmanw02's Avatar
Nice comparison. However, the Zoom is Kevlar and the Ram is organic, hence the difference between the Ram having rivets and the Zoom being one piece. But I'd side with you in saying the Zoom disc is probably the stronger of the two.
What flywheel did you use?? The one we had in the shop had a very thick aluminum one, he said it came with the Zoom clutch...
Quick Reply: What lt1 clutch should I go with?
