truck fuel rails or LS1 fuel rails?
Old 03-05-2009, 01:53 PM
BlueZee28's Avatar
Default truck fuel rails or LS1 fuel rails?
Will truck fuel rails and injectors work well with an LS1 intake manifold? I can buy LS1 fuel rails and injectors if I have to, but if the truck parts will work fine then I'd rather not spend the extra money.
Old 03-09-2009, 05:30 PM
BlueZee28's Avatar
Anyone have some input???
Old 03-10-2009, 11:09 AM
500@10psi's Avatar
it seems to me that the rails would flow better but with the size for the truck manifold i dont think the rails will fit on the ls1 at the very least you might have some clearance issues
Old 03-10-2009, 04:14 PM
BlueZee28's Avatar
I think I'll just go with the LS1 rails because I had heard about having to do some extension modifications to the truck injectors if I were to use them with the LS1 manifold. I found a set of rails and injectors for real cheap I'll probably just pick them up soon.
Old 03-10-2009, 05:15 PM
thunderstruck507's Avatar
doesn't the truck rail stand really tall?
I have a rail and '99 ls1 injectors for sale in the for sale section
Old 03-10-2009, 05:23 PM
BlueZee28's Avatar
Yea...if you want to run the truck intake in a Camaro you need at least a 3" cowl hood....I figured a new intake would cost me less than a new hood, plus I like my stock hood.
I'm trying to find some rails and injectors locally, if I can't pick some up I'll hit you up.
Old 03-10-2009, 05:38 PM
sman's Avatar
Nope cant use the rails on the ls1 intake wont fit under the hood and the injectors have a different connector on them than the ls1 ones do.
Old 03-10-2009, 05:52 PM
cgslow77's Avatar
i have a set of lq4 injectors and rails for sale
Old 03-10-2009, 05:53 PM
BlueZee28's Avatar
So do I now.
Quick Reply: truck fuel rails or LS1 fuel rails?
