Completing the LS1 in to LT1 swap, gauge problems now.
Well the 99 LS1 in to 97 LT1 car swap is almost done. I've only run in to one problem so far, and that's the gauges. I rewired the tach, temp, etc to the body harness. The gauges come on, but the odometer will not show. The tach isn't working, and i don't think any of the gauges are. The backlight for the odometer does show up, and the lights work when you turn the headlights on.
Anybody have any suggestions?
I printed out the diagram for the gauges and stuff so I'm going to go start checking on it tonight, but I'm guessing someone else who has done the swap might have ran in to this problem.
Also I had a fuel pump relay problem. When I bypass the relay the car starts and runs fine. I think alldata had some misprints on their pinouts, because i believe I found the right FPR + signal. It's listed as IAC motor in or out on the body harness connector.. which makes no sense. Anyone else run in to that?
If the odometer is not comming on then you have no power to the cluster. I'd start there.
How did you wire the fuel pump relay? The LS1 uses a relay under the hood while the LT1 has it behind the driver side kick panel. To make it work you would have had to move the fuel pump relay trigger wire from one of the connectors under the hood to one of the connectors that run into the interior.
Re'
Re'
Well it turns out that the fuel pump relay and the gauge cluster share a ground. Once I fixed that, they both worked!
I'm happy to say my first LS1>LT1 swap is on the road and driving. Other than needing a tune (for the MS3), it runs like a champ!
