HPT - No signal from O2's.
Old 03-05-2009, 08:27 PM
Josh18Fan's Avatar
Default HPT - No signal from O2's.
Total newbie to tuning. Car is a 1998 Z28 M6 with longtubes, no cats/rear O2's. When scanning the vehicle, the O2B1S1 and O2B2S1 do not show any values. The car runs fine, but gets horrific gas mileage, I've never had a tank go over 300 miles (15.5gal). No SES codes for either oxygen sensor, although one is spliced and extended from the previous owner's header install. Any help is appreciated.
Old 03-06-2009, 07:47 AM
Moderator
jimmyblue's Avatar
Even a failed or missing sensor should show
-some- value.
The sensor PIDs, they are on the table-view
list, right? You might try dropping them and
then re-selecting from the list of validated
PIDs.
Old 03-06-2009, 07:48 AM
Josh18Fan's Avatar
-some- value.
PIDs.
They are on the table-view list. I'll try what you said and re-add them. Thanks.
Old 03-06-2009, 09:04 AM
dubrado's Avatar
I had a similar issue, I just went ahead and repalced them and it was ok after that.
dunno
