HELP - SD tuning w/HPT
Old 03-05-2009, 08:55 PM
Eagle02's Avatar
Default HELP - SD tuning w/HPT
I'm so frustrated right now. Basically just got up and left the car in the garage.
Hopefully someone sees what I'm doing wrong on this. I can't even get the car to run to begin SD tuning.
Thanks for any ideas...
File Type: hpt
File Type: hpl
Old 03-05-2009, 08:57 PM
Eagle02's Avatar
My timing stays crazy low too for some reason... ~10* @ idle?
Old 03-05-2009, 09:09 PM
Eagle02's Avatar
Well found my high octane wasn't copied over the low octane table, but its not a massive difference... going to flash and see what it does.
Old 03-05-2009, 09:23 PM
LS1TECH Sponsor
foff667's Avatar
Because you have your dtc's set so that the maf won't fail upon startup you might not be going into speed density mode, you might want to fix that so at least your sure its going into SD.
-Bill
Old 03-05-2009, 09:28 PM
LS1TECH Sponsor
foff667's Avatar
Why is your TPS reading 23% at idle in a non ETC car? Also your map reading is 90+kpa which is super high at idle.
Old 03-05-2009, 09:32 PM
Eagle02's Avatar
Same stuff. Not much better.
File Type: hpt
Old 03-05-2009, 09:34 PM
Eagle02's Avatar
BILL! Man am I happy to see you!
I have to hold the throttle down that far to keep it running @ all...
I have no idea. What could cause that? I installed a cam, 232/238 .599/.601 on a 113 lsa. Would that do it?
Old 03-05-2009, 09:36 PM
Eagle02's Avatar
-Bill
They're set to SES enable & option "1 - MIL on second error"... where else do I look?
Old 03-05-2009, 11:52 PM
Frost's Avatar
Your AFR error seems to average about -20%. Make a large to the VE of 15% or so through the idle area to help get it running. This is a normal part of roughing in a VE if you have no suitable base. Just getting fueling closer will get things back to stable, assuming they were previously stable with the MAF hooked up.
Old 03-05-2009, 11:53 PM
Eagle02's Avatar
Bill found the magic issue... I've got 42lb injectors. Somehow my KPA table got lost in the mix and set back to stock. I set it up correctly... and whoa, check that out... everything acts much more like its supposed to!
Bill also gave the advise to set the DTCs to set on the first MIL rather than the 2nd. This puts you into SD mode on the first start, rather than the 2nd.
Old 03-05-2009, 11:56 PM
Frost's Avatar
ahh good to hear.
Old 03-05-2009, 11:57 PM
Eagle02's Avatar
Thanks for the reply, Frost!
