Generation III External Engine - 85MM MAF Harness Adapter?
JoeMack
03-05-2009, 10:11 PM
Does anyone know where I can find the wiring harness adapter to go from the stock LS1 MAF to the GM 85MM MAF? Does this adapter eliminate the need for the original IAT sensor? Thanks:usa:
slws608
03-05-2009, 10:52 PM
casper electronics makes one. Yes it should eliminate the stock iat sensor since the 85mm maf has the iat built in.
http://www.casperselectronics.com/store2/product_info.php?cPath=27_42_51&products_id=1072
HavATampa
03-05-2009, 11:11 PM
Fast Toys sells an adapter too and yes it does do away with the IAT in the lid. The problem with the adapter is now you have a pile of connectors hanging off the throttle body. I ended up cutting the ends and soldering and shrink wrapping the adapter to the stock wiring and it looks much cleaner.
http://fasttoys.net/shop/product_info.php?cPath=84_24_27_45&products_id=1620
JoeMack
03-06-2009, 08:28 AM
Is this the same thing?:usa:
http://www.lsxtune.com/shop/product_info.php/products_id/927%7B2%7D1
TORCHD 02 TA
03-06-2009, 10:34 AM
Is the same thing?:usa:
Yes that looks to be the same. How much is that one? I may pick that one up. I do not feel like spenidng $30 on a sensor
EDIT: i saw the price for $19.99... now how long do you want it to be? That i have no idea. It comes 4" or 8"
I went to a junkyard, grabbed the connector and about 5in of wire from a suburban, took it home looked up the wire colors(all the same except the IAT, the purple is brown I think, if you want ill go look) and soldered it together, you cant tell its not factory.
1999BlueTA
03-06-2009, 02:32 PM
Thats where I got my adapter from I ordered the one without the IAT because I'm running a regular MTI lid thats already drilled for the factory IAT they have a buch of different shipping options I only paid like $2 for shipping and it arrived in about 3 days but I think thats the one if you are unsure pm FROST here's the link to the one I ordered
http://www.lsxtune.com/shop/product_info.php/cPath/109_183/products_id/1026
JoeMack
03-06-2009, 03:58 PM
Just ordered $22.01 shipped:usa:
TORCHD 02 TA
03-07-2009, 10:27 AM
How many inches did you ordefr with it? It comes with 4" or you can change it? So did you just do 4"?
Thanks
JoeMack
03-07-2009, 02:17 PM
Thanks
I ordered 4". Looks like it should work.:usa:
01Z0H6
03-07-2009, 06:45 PM
Money well spent... ;)
TORCHD 02 TA
03-08-2009, 01:41 PM
w00t i just ordered mine :)
Eagle02
03-13-2009, 09:50 AM
I also ordered one. Has anyone that's ordered from LSxTune gotten their adapter yet? Everything work fine?
TORCHD 02 TA
03-13-2009, 11:11 AM
I orderd mine on last Sunday (3/8) and they just shipped it on thursday (3/12) :rolleyes:
taking forever. but then again my car is still in storage so it does not matter
JoeMack
03-13-2009, 12:49 PM
Ordered mine on Friday (3/6). Shipped Thursday (3/12)?:usa:
PowerShift408
03-13-2009, 03:13 PM
Got mine off of eBay along with my 85mm MAF.
