96 lt1 head bolt torque what is it?????
Old 03-06-2009, 01:55 AM
robsquikz28's Avatar
Question 96 lt1 head bolt torque what is it?????
aluminum heads off firebird.....since are search dont work at all its hard to find this but i saw its suppose to be like 22 in lb then 80* crap
all in all is there any definative actual number to tty these bolts to like 65 ft lbs on all bolts or what.....someone help please
only helped me a bit
Old 03-06-2009, 03:07 AM
gregrob's Avatar
22ft lbs, then 80deg.
I would get a deg tq wrench and do it the right way
http://shbox.com/ci/head_assy.jpg
Old 03-06-2009, 03:48 AM
95 TA - The Beast's Avatar
That (22ft lbs, then 80deg) spec is only for TTY (Torque To Yield) headbolts, which SHOULD NOT BE RE-USED!!!
If you have a '96 that used TTY headbolts you MUST replace them once the are removed.
Now, that being said, go buy some nice ARP headbolts and torque them to 70ft/lbs (the 'old' spec was 65ft/lbs, but ARP revised that about this time last year).
Old 03-06-2009, 04:44 AM
RamAir95TA's Avatar
Some additional info -
If you are using new ARP bolts, I suggest torquing them in 3 stages; don't go 70 ft./lbs. all at once.
First pass 23 ft./lbs.
Second pass 45 ft./lbs.
Third pass 70 ft./lbs.
95 TA is right though - DON'T reuse TTY bolts!
Old 03-06-2009, 06:59 AM
shbox's Avatar
The full info for the head bolts:
Torque-to-yield for head bolts
All bolts first pass = 22 lb. ft.
Second pass:
Long and medium bolts additional 80°
Short bolts additional 67°
You will need a torque wrench and a torque/angle meter (such as the Lisle 28100 below). Unlike stock type bolts, if you buy the ARP bolts, you can reuse them and you can still use the torque/angle method of tightening (or you can just use the straight torque only method).
Old 03-06-2009, 07:46 AM
riceburnerZ28's Avatar
this thing looks like some sort of torturing device ...hahaha
[/QUOTE]
Quick Reply: 96 lt1 head bolt torque what is it?????
