Automatic Transmission - stall or trans bad
98z8uup
03-06-2009, 08:47 AM
I am haveing a hard time trying to find out which is bad. I have a stock stall with a 4l60e trans. The shift good but sometime when I jump on it. It will not pulled until I take my foot off the gas, then it will make a noise then it will pull. It does this sometimes. It does this at low or high speeds.
dondb
03-06-2009, 10:28 AM
Sounds like it could be either? I think the only way you can really tell is if you take out the Trans. for inspection. Maybe one of the sponsers will be of more help!
98z8uup
03-06-2009, 06:12 PM
Thanks I may end up getting a new trans and stall from one of the sponsers.
tptransmission
03-06-2009, 06:31 PM
First check the basic like fluid level and condition of the oil (burnt etc). Then check to see if there are any codes.
9000th01ss
03-06-2009, 08:25 PM
It's the transmission. At this point the converter and cooler are probably full of garbage. I'd start by dropping the pan and looking for metal and other trash.
performabuilt
03-06-2009, 08:57 PM
I would agree on pulling the pan to see whats in there but it does sound like you are in need of a trans and converter:(
98z8uup
03-06-2009, 09:26 PM
Thanks, the tran s has a lot of miles on it. So I will be looking into getting one real soon.
LS1nut377
03-07-2009, 12:14 AM
ya that what i would start doing is preparing for a tranny swap. good luck. i know im going to need one in the next year or so....
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
