K&N Filter Cleaning
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
I have had mine 9 years..I wet it with the hose...drip Sunlight dish soap on it and then spend 5 minutes spraying both sides until no more soap is left...let dry overnight..and then use a little bit of 'filter treatment' on it.
I use their recharger kit, available at most parts stores. Don't over oil it and you should be fine. Been using the same filter since '01 with no issues.
You should wash all the old oil and crud out of it once every so often.....will last longer...[Recharger Kit..thats the words I was hunting for..]
And I'd like to add that the oil they put on before boxing has time to migrate through the filter. So put on a little oil and let the filter sit for while.
