are rolloer rocker saposed to be a little noise?
Old 03-06-2009, 02:58 PM
starbucks's Avatar
Default are rolloer rocker saposed to be a little noise?
Hey guys i just installed some 1.6 com pro mag on the car with new spring and a freind of mine told me there rockers should make any noise since that are a full roller. well my rockers do make a little more noise than the stock 1.5s is it saposed to be this way or is my frined right. I adjusted the valves with the motor running and tighten them down a 1/4 of a turn then set the poly lock and im sure non of them are lossed i checked three times.
Old 03-06-2009, 03:00 PM
shbox's Avatar
Pro Mags have been known to have a little noise.
Old 03-06-2009, 03:03 PM
StealthFormula's Avatar
Yep my Pro-Mags are pretty noisy.
Old 03-06-2009, 03:06 PM
Rocky70304's Avatar
Not real noisy, but a little bit more than stock. I've used the pro mags and I could hear a little noise with the hood up, but with the hood down, couldn't hear anything.
Old 03-06-2009, 03:22 PM
96capricemgr's Avatar
Roller rockers are noisier than stamped. That is why the LT4 Vette with it's stock roller rockers got composite valve covers, to dampen the extra noise.
Old 03-06-2009, 03:46 PM
SpeedDensityZ's Avatar
Mine are also noisy.
Old 03-06-2009, 04:03 PM
dlk1950's Avatar
Mine are noisy also.
Old 03-06-2009, 04:12 PM
ss.slp.ls1's Avatar
If properly adjusted, they should only be a little noisier than stock, now if you hear tapping on the valve covers or clanking, that's a different story.
Old 03-06-2009, 04:18 PM
xx_ED_xx's Avatar
Hands dictionary to OP
Old 03-06-2009, 05:59 PM
starbucks's Avatar
Thanks for all of the help guys i think i am going to readjust the valves with the motor off this time instead of on just to make sure that every thing is right
Old 03-06-2009, 06:14 PM
ss.slp.ls1's Avatar
Actually dialing the adjustment with the motor running is more accurate and consistent.
Old 03-06-2009, 06:24 PM
rusty2198's Avatar
yep my promags drove me nutts I thought they were loose but adjusted twice and it is what it is. Also got a LT4 knock module 2 days after installing the promags and it made my car feel like a new car.
Old 03-06-2009, 11:36 PM
shbox's Avatar
...as a matter of opinion...
Engine on or off works just fine. It's more of a personal preference.
Quick Reply: are rolloer rocker saposed to be a little noise?
