pro charger p1sc
pro charger p1sc
hey guys im going to be picking up a pro charger p1sc has anyone run this unit on there lt1 ?? do i need to do anything besides the kit ? do i need bigger injectors ?? im running 30lb svo injectors i have a stock bottom end whats the maxx amount of boost i can run safely ?if anyone has pictures of there lt1 super charged can you please post pictures any brand im installing it myself
the p1sc is the base supercharger that leaves you wanting more boost. My buddy got one w/ twin intercoolers. it slipped so he put the upgraded belt kit on it, then he wanted more boost so he put a diff pulley on it. then broke the crank on the snout
when we put the system on, the sc had to be reclocked so things would line up so beware. we put it all on with a lift so that was a big help the fmu kinda of sucked get a walbro/boost apump and a GOOD tune
I thought the kit that came with the LT1 ran 8 lbs. I have 42 lb injectors, and I know they handle around 500, you may need bigger injectors depending on what else you have done to the car. I'm sure you'll love the charger though. Good luck!
