pro charger p1sc
pro charger p1sc
hey guys im going to be picking up a pro charger p1sc has anyone run this unit on there lt1 ?? do i need to do anything besides the kit ? do i need bigger injectors ?? im running 30lb svo injectors i have a stock bottom end whats the maxx amount of boost i can run safely ??
if anyone has pictures of there lt1 super charged can you please post pictures any brand im installing it myself
I replaced my 30#'s with 42#'s in order to eliminate the fmu. On the stock bottom end make sure you get a good tune and I wouldn't run more than about 6lbs of boost. Installation is pretty straight forward; you might want to contact procharger and they will send you an installation manual that's specific for the LT1.
LS1TECH Sponsor
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
http://www.exoticperformanceplus.com...tCar.php?car=7
There are a lot of pictures at the above link. Bob
