o2 sensors
Old 03-06-2009, 04:01 PM
banditz28's Avatar
Default o2 sensors
i live in NC and the awsome state has emissions regulations. i have gutted cats and am a little past on the inspection. the emulator i bought off zzp dosent clear the code. i have heard of people tuning out the code for the rear o2's but will this work on inspections. they only do visual as well as hook up the obd2 to see if they are getting good numbers from the o2s. i have hp an hp tuner but its the first version. any help is appreciated.
Old 03-06-2009, 04:16 PM
99blkt/a's Avatar
If you turn the codes off you should pass just fine. I have !air,!egr,!cats, all show ready. Since you have "cats" on there then you should pass the visual w/ no problems. I dont know anything about the hp tuner, mine weren't done that way. Someone else might know about that
Old 03-06-2009, 04:35 PM
99LS6SS's Avatar
I know on the newest version you can go into your engine diagnostics then to DTC's and switch everything about the bank 1 sensor 2 and bank 2 sensor 2 to never set off the SES light. Then just clear your codes.
Old 03-06-2009, 05:51 PM
boola1341's Avatar
I used the my handheld predator to turn off my rear O2's
Old 03-07-2009, 12:36 PM
Engine_HP's Avatar
+1
thats what i was gonna say
Old 03-10-2009, 02:43 PM
banditz28's Avatar
thanks for the help
