Automatic Transmission - torque arm bolts just spinning
View Full Version : torque arm bolts just spinning
pooker
03-06-2009, 06:01 PM
I am trying to undo the two bolts that connect the torque arm to the rear end. They are lose , but are just spinning and will not loosen. What can I do to fix this? I assume this bolts are threaded into the rear end. Has anyone ever had this problem before?
tptransmission
03-06-2009, 06:12 PM
No there are nuts on the top.
mike13
03-06-2009, 07:23 PM
I tip when you put them back in on installation use a long punch or phillips head screw driver to line up the arm and housing holes. I had to use a floor jack under the rear to adjust the angle to get the holes lined up.
waldershrek
03-06-2009, 10:35 PM
:nod:
Putting them back in you will most like have to play with a floor jack under the pumpkin to get the right angle so the holes line up.
smokintiresz28
03-06-2009, 10:37 PM
one of the bottom is just a stud for the mount brace undo the top first and remove the outer piece it fits in there like a clam shell
tptransmission
03-06-2009, 10:39 PM
I believe he is referring to the ones on the rear axle.
pooker
03-06-2009, 10:48 PM
Dang I feel stupid! I got it now. I even broken an impact socket in half using one of those nut crackers to break it in half.
01ssreda4
03-07-2009, 02:06 AM
:nod:
very true, sometimes it takes a couple times to get it just right.
