Turbo exhaust housing temp on rear mount..
I would like to see how my turbo exhaust housing temperature measures up to some fellow rear mount turbo guys.
If you can list if your using-
1. Manifolds or Headers
2. Size pipe to turbo
3. Is it wrapped up
4. Are you using a turbo blanket
I have long tube headers still with a 2.5inch Y to a 2.5 all the way to the turbo with a recently installed turbo blanket with the exhaust wrapped just after the headers all the way to the turbo.
I started my car and let it idle for 5-8min to get it warmed up and took a temp reading with my temp gun and it read 170 degrees.
I then took a spirited drive for about 10min and measured the temp right after pulling into the driveway and read about 400 degrees. Just wondering how hot your turbo gets.
3. Is it wrapped up
i recorded 528 F out of my tailpipe at 10-12psi...it was 42 F air temp...Fluke II with a K type thermocouple.
Stock manifold
2" to turbo
fully heat wrapped and hvac foil tape[prevents moisture penitration]
no blanket
FYI,i have a 88 Nissan 200sx v6 rear remote turbo.
Stock manifold
2" to turbo
no blanket
