moisture under oil cap- might have problem
Old 03-07-2009, 11:35 AM
slayerized6's Avatar
Default moisture under oil cap- might have problem
since i got my headers done i noticed ive been creating some whites smoke out of the exhaust. i looked up some articles and it said if you running rich you would get black smoke, so it got me thinking. this is what i noticed just now.
-white smoke out of exhaust. not alot, very minimal. occurs more often during cold starts though
-moisture under oil cap
-yellow, snot like material in oil filler tube and on oil cap
-coolant resivor is full. color looks normal.
-when i idle the car with the radiator cap off, if you look close enough there is some white smoke coming of
so what could be creating white smoke and moisture under the oil cap?
Old 03-07-2009, 11:43 AM
cruzc5frc's Avatar
I usually have something similar after the car has sat for awhile, other than that if the car is running fine you should be ok.
Old 03-07-2009, 11:45 AM
how would you classify a while? i DD my car so the longest it ever sits for is maybe 12 hours. im gunna post a vid up, because i also have a noise coming from the TOB (i think). i just want to some imput from other ppl on that too.
Old 03-07-2009, 12:09 PM
i just notcied some water in the exhaust as well
Old 03-07-2009, 12:24 PM
slvr98camaro's Avatar
for one, if you are getting water in your oil, you arent going to get white smoke, thats ONLY if you are burning coolant
you live in new york, where its cold, its probably just condensation building up
i can tell you this, my car smokes more than any other car on the road (when its cold out) and has always freaked me out, but im not burning any coolant
Old 03-07-2009, 01:02 PM
LS6427's Avatar
You should be just fine. Next time you drive along enough, like 20 minutes, take the oil fill cap off and see if that stuff is all gone. Sounds like condensation in the crankcase from sitting, its normal. Water coming out the pipes, while it can mean a dropped sleeve in a sleeved engine or a blown head gasket in any engine, is also probably condensation.
Old 03-07-2009, 02:08 PM
thanks for the response all. yea, i noticed last summer i was never smoking so i figured it was just the cold weather. i think the smell from running rich coupled with white smoke had me freaked out and all. overall, the car drives fine except for a noisy spec TOB.
Quick Reply: moisture under oil cap- might have problem
