New LS1 Owners - Newbie Tech - Drive by wire peddels
View Full Version : Drive by wire peddels
waynehartwig
03-07-2009, 12:16 PM
Putting drive by wire in my 04 Rubicon. The donor is an 08 Sierra. The peddle I have has too much of an arch from the mounting point to the peddle, like it was going around the steering column before? Anyway, that arch is causing it to either hit the tunnel or the steering column, depending on location and etc.
Anyone have any ideas on which peddle would work better?
sman
03-07-2009, 10:02 PM
I can take some pictures of my camaro one and get them to you see if its any better.
waynehartwig
03-07-2009, 10:24 PM
I'd appreciate that!
I just ran across a GTO build on a Chevelle website, where he used an 07 Monte Carlo pedal - I like the look on that one...
sman
03-07-2009, 10:41 PM
If mine works out id be happy to sell it to you!(Assuming your interested) My car had a DBW v6 in it and im in the middle of DBC v8 swap.
waynehartwig
03-08-2009, 05:02 PM
The main problem is time in getting it to me, not cost of buying one. The one I mentioned above, is only $51 from RockAuto.com, but again it's the time issue. Tomorrow I'll go down to the local yard and see what they have.
The point to this thread was to see what others were using, so that I might find a better match than what I have already.
