Vibration after Wheel Hop
I took my car to the track last sunday and when the car leaves I had a real bad wheel hopping problem. After I left the track driving the car home there was a very bad vibration coming from the rear of the car. It only happens around 30 mph up to about 70 mph....Any help would be great..... I have checked the drive shaft it looks ok. PLEASE HELP
if thats not it, i could see maybe a axle bent from the hopping but that may be a stretch.
that or driveshaft.
i really doubt that its a tire that through a weight but guess that also could be a option
that or driveshaft.
narrowed the problem down to the drivetrain. Replaced u-joints and bushing in tailshaft, pulled out the axles and checked them, and also checked the motor mounts. The vibration is felt at too low of a speed to be the tires out of balance. Any more suggestions? The vibration is felt in low rpm's all the way up to higher rpms's.
