Tach hook up
Tach hook up
o im hooking up my tach on my 93 camaro....where does the green wire go to get the rpm readings it says the green wire on the coil but im not sure what wire and where at ...Input please...thanks
Run it right off the coil, works best I feel on our non PCM cars (we're ECM remember). It's the white white, I'd tap in after the (what I assume is) a filter.
Though for anyone reading this with a 94+ it's PCM connector pin A13
