6.90's in a junkyard 6.0
Old 03-07-2009, 07:16 PM
billyflantos's Avatar
Default 6.70's in a junkyard 6.0
put a 6.0 out of a 2002 truck stuck some stock 799 heads milled .040 and some thin head gaskets and a polluter cam from tick perf. victor carb intake and a msd 6010 box in my 85 turbo regal untuned went 6.90's shifting at 6500on my third and last pass.the higher i turned the motor the faster it went.it went a 7.13 first pass shifting at 6000 getting a feel for the car....
Old 03-07-2009, 07:24 PM
djsanchez2's Avatar
Holy crap that's low 11's / high 10's Congrats man
What size carb you using?
Old 03-07-2009, 07:32 PM
750 aed
Old 03-07-2009, 08:10 PM
rojs234's Avatar
Great job man!! Can't wait til you post more info on it.
Old 03-07-2009, 08:12 PM
thanks ron,it came on strong at the big end....
Old 03-07-2009, 10:02 PM
dmracing's Avatar
You have any pics of the engine?
Old 03-07-2009, 10:04 PM
i'm going to get some pictures and a vid as soon as i can....
Old 03-07-2009, 10:31 PM
dmracing's Avatar
whats the duration and lift on that cam?
Old 03-08-2009, 11:14 PM
240 plus duration and a little over 600 lift,the cam makes great midrange...
Old 03-14-2009, 11:19 PM
3200 lbs full int. and two chamber flow master mufflers no nitrous...heads are stock except for having them milled .040 i think 6.70's wont be out of the question...
Old 03-15-2009, 09:30 AM
bgblockelcamino's Avatar
i have a very similar setup. can't wait to run it.
Old 03-15-2009, 04:08 PM
BLWN1's Avatar
Damn, nice.......... what suspension, gears, tranny, and conv if I missed it?
Old 03-15-2009, 05:23 PM
stock susp. with comp.eng shocks and qa1 coil springs 4.11 gear turbo action 4000 conv and turbo 350 had mid 1.40 short times.it was 80 plus degree's that day and had a very strong head wind...
Old 03-21-2009, 08:50 PM
went back to the track today and put more timing in it picked it up a tenth,6.80's with more in it.seems like ls motor's with carbs like timing,also picked up the mph.....
Old 03-21-2009, 09:10 PM
xpndbl3's Avatar
what's your total timing now?
Old 03-21-2009, 09:44 PM
DMMizell's Avatar
Default 9.95 at 137.20
Went 9.95 at 137.20 today with a Junkyard 6.0!
N/A Rapid Motorsports Dominator 2X cam,
soundclip http://www.youtube.com/watch?v=zE8vk...e=channel_page
Thanks,
Dave
Old 03-21-2009, 10:41 PM
djsanchez2's Avatar
What tire are you using out of curiousity?
Old 03-21-2009, 11:10 PM
still running short tire's 26 by 10's and it has 36 degree's of timing number 6 pill,dmmizell sounds good what kind of mufflers do you have on it,sure runs good how much does it weigh.like to know some more info on it them L92 heads kick ***...
Old 03-22-2009, 07:21 AM
DMMizell's Avatar
Default info
Billy,
No mufflers, just 3 inch dumps. It weighs 2900lbs which helps.
Since I was building this as carb setup and had to buy a manifold, the 317 heads got sold at a swapmeet.
Turn it to 7000 at shiftpoint and through the traps at 7K.
I did not mean to hijack your thread..... just wanted to post what is possible with these junkyard 6.0's!
Dave
Old 03-22-2009, 09:04 AM
just want to know how i can get a little faster,is that 2900 with you in it.i'm thinking of putting heads on my car and dont what way to go...i do need a electric water pump
Quick Reply: 6.90's in a junkyard 6.0
