wiring question
Old 03-08-2009, 12:38 PM
promalibu461's Avatar
Default wiring question
is there a way to have a data port without the body control mod.?
Old 03-08-2009, 03:25 PM
poconojoe's Avatar
Yes, you just wire it to the PCM. Most swap harnesses are done this way
Old 03-08-2009, 06:55 PM
LS1MCSS's Avatar
what harness/pcm are you using?
Old 03-08-2009, 07:02 PM
5.3 2000 silverado 1500
Old 03-09-2009, 07:33 PM
trentonz28's Avatar
Default oil pressure signal
While we're talking about harnesses, I have a question! I have a 2004 LS1 from a GTO and I'm re-working the harness, can anyone tell me if the pcm uses the oil pressure for anything other then activating the warning light ? I will remove the pins and just use the original light in the first gen camaro if not needed. Thanks
Old 03-09-2009, 11:57 PM
V8Rumble's Avatar
(Pretty sure that it doesn't...)
Old 03-10-2009, 07:06 PM
bczee's Avatar
I don't beleive that the Oil input is really needed for the PCM other than a gauge that doesn't really work well or a idiot light. I don't use the input on my 99 LS1 swap.
Old 03-10-2009, 10:19 PM
