231/237 yes it sounds good but how does it run
i have read alot of post about this cam and all i get is how good it sounds. i would like to see more time slips or dyno numbers. the question is, how fast are the cars with this cam and what is the rest of your combos? please reply.
LS1Tech Premium Sponsor
Re: 231/237 yes it sounds good but how does it run
You might run a search on it, there are several dyno sheets floating around with & without heads. Are you going with heads or cam only?
Jason
Jason
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
I am very happy with my cam. I went 11.6 @119 - not the best but it was on a terrible 1.62 60'. The car drives great. There is plenty of low end, despite what some say, and a ton of top end.
My car did 420rwhp through a ford 9'' with 4.30 gears, and I lost 29 rwhp swapping the 10 bolt and 9''.
All in all, great cam.
Dyno numbers in the sig. I'm installing an electric water pump and going back to the dyn in a week or so. The numbers should be even better than what I have now.. Track times on Oct 25 if I get my transmission back in time.
Jason, i was going to go with cam only for now until i get some more money together. this cam is to big for me right now but i was just wondering the numbers on it. how long is that sell good for?
