Gets close to boost and sputters
Old 03-08-2009, 06:39 PM
98Camarod's Avatar
Default Gets close to boost and sputters
I was doing some logging and I was accelerating slowly, noticed I was close to 0 psi and kept the same slow acceleration I was doing about 70 and it sputtered. This is all following the boost referenced regulator install. I changed the IFR and the offsets to the corresponding 0 map value. I had a steady 58 psi the entire log. Not really sure why the hell that happened. Here's a link to the log and tune:
https://ls1tech.com/forums/pcm-diagn...t-ref-fpr.html
